Introducción
Behold the iClicker. This learning device is used in some college classrooms to help make the learning process more interactive. Course instructors can ask multiple choice questions and students can respond by pressing the button that corresponds to the answer they desire.
Este desmontaje no es una guía de reparación. Para reparar tu iClicker, utiliza nuestros manuales de servicio .
Behold the iclicker in all its interactive and educational beauty.
  • Behold the iclicker in all its interactive and educational beauty.
Agregar Comentario
Place the device on a flat surface, buttons facing down.
  • Place the device on a flat surface, buttons facing down.
  • Remove the battery cover and the three batteries within.
Agregar Comentario
Remove the two visible screws using a #00 Phillips screwdriver. Oops! Don't forget a hidden third screw beneath the factory label.
  • Remove the two visible screws using a #00 Phillips screwdriver.
  • Oops! Don't forget a hidden third screw beneath the factory label.
  • Peel back the corner of the label to reveal the hidden screw.
  • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
Agregar Comentario
Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers. For the more resistent iclickers, a spudger may be employed to separate the pieces.
  • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
  • For the more resistent iclickers, a spudger may be employed to separate the pieces.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Your iclicker is now exposed for all its worth.
  • Your iclicker is now exposed for all its worth.
  • The back panel can be set aisde, as the remaining components are housed in the front panel.
Agregar Comentario
Using a spudger, gently pry the battery connectors from the front panel. Using a spudger, gently pry the battery connectors from the front panel.
  • Using a spudger, gently pry the battery connectors from the front panel.
Agregar Comentario
If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
  • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
Agregar Comentario
The buttons can be easily removed from the front assembly sans spudger.
  • The buttons can be easily removed from the front assembly sans spudger.
Agregar Comentario
Don't lose the small LED cover sitting precariously in the front panel.
  • Don't lose the small LED cover sitting precariously in the front panel.
Agregar Comentario
Your iclicker is now disassembled.
  • Your iclicker is now disassembled.
Agregar Comentario
What is an iClicker ?
furbies - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 6,529
