Introducción
This guide will show you the quickest way to remove the front of the device so you can get to deeper parts of the device.
Partes
No se requieren partes.
Using a philips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device and place aside. Using a philips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device and place aside.
  • Using a philips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device and place aside.
Agregar Comentario
Remove these seven 11.5 mm screws and place aside.
  • Remove these seven 11.5 mm screws and place aside.
Agregar Comentario
Lift the right side off of the device and place aside.
  • Lift the right side off of the device and place aside.
  • Repeat for left side.
Agregar Comentario
Lift the top gently but firmly from the back of the device and allow to rest on the back without reattaching it.
  • Lift the top gently but firmly from the back of the device and allow to rest on the back without reattaching it.
  • CAUTION: Do not pull the top too far as there are wires attached to it.
Agregar Comentario
Lift up gently on the tabs indicated to disengage them from the hooks holding them in place. Lift up gently on the tabs indicated to disengage them from the hooks holding them in place.
  • Lift up gently on the tabs indicated to disengage them from the hooks holding them in place.
Agregar Comentario
Lift up the top while firmly sliding it towards the back of the device.
  • Lift up the top while firmly sliding it towards the back of the device.
  • CAUTION: Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
  • The next step is a zoom-in of the indicated area.
Agregar Comentario
Using forceps or fingers, remove the small black wire indicated.
  • Using forceps or fingers, remove the small black wire indicated.
  • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
Agregar Comentario
This step deals with the indicated area of the device. Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture. Gently pull on the cord near its base until it comes free of the restraint.
  • This step deals with the indicated area of the device.
  • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
  • Gently pull on the cord near its base until it comes free of the restraint.
Agregar Comentario
This step deals with the indicated area of the device. Lift the indicated tabs out until the restraint looks like the final picture. Gently pull on the cord until it comes free of the attachment.
  • Lift the indicated tabs out until the restraint looks like the final picture.
  • Gently pull on the cord until it comes free of the attachment.
  • The top section of the device should now be free of the body. Place it aside in a safe place.
Agregar Comentario
This step deals with the indicated portion of the the device. Lift the indicated tabs out until they look like the final picture. Gently pull on the cord until it comes free of its restraint.
  • This step deals with the indicated portion of the the device.
  • Lift the indicated tabs out until they look like the final picture.
  • Gently pull on the cord until it comes free of its restraint.
Agregar Comentario
This step deals with the indicated area of the device. Neither of the indicated cords have restraints on them like the previous ones. Simply use tweezers or fingers to pull firmly on the base of each cord until it comes free. Neither of the indicated cords have restraints on them like the previous ones. Simply use tweezers or fingers to pull firmly on the base of each cord until it comes free.
  • Neither of the indicated cords have restraints on them like the previous ones. Simply use tweezers or fingers to pull firmly on the base of each cord until it comes free.
Agregar Comentario
This step deals with the indicated area of the device. Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
  • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
Agregar Comentario
This step deals with the indicated area of the device. Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device. Rotate device 180 degrees and repeat for other side.
  • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
  • Rotate device 180 degrees and repeat for other side.
  • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
Agregar Comentario
Wiggle the front gently while pulling it forward until it comes free of the body of the device.
  • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
NathanB
Miembro Desde 13/04/11
191 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-1, Regan Spring 2011 Miembro de Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 Miembros
5 Guías creadas
Excellent and clear instructions, thankyou. Only trouble is the CD Changer device door is not opening! As I have not actually carried out the Front Panel removal at present I am hoping my problem will expose itself when I complete your instructions in practicality. Thanks again. Denis.
Denis Parker - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 3,280
