Saltar al contenido principal
Disassembling Speak And Spell Case
Qué necesitas
  1. Disassembling Speak And Spell Case, Case: paso 1, imagen 1 de 2 Disassembling Speak And Spell Case, Case: paso 1, imagen 2 de 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: paso 2, imagen 1 de 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Conclusión
bushing
Miembro Desde 04/23/10
10,247 Reputación
13 Guías creadas
Un comentario
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 4,960
