Introducción
This guide will help you to disassemble your Sony Ericsson T68i.
Remove the battery from the back. Remove the battery from the back.
  • Remove the battery from the back.
Agregar Comentario
Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips. When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips. When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips.
  • Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips.
  • When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips.
Agregar Comentario
Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
  • Unscrew all four Torx T6 screws.
  • Keep in a safe place.
Agregar Comentario
After removing the screws, the two halves will separate.  If not, then pry them gently apart. After removing the screws, the two halves will separate.  If not, then pry them gently apart. After removing the screws, the two halves will separate.  If not, then pry them gently apart.
  • After removing the screws, the two halves will separate. If not, then pry them gently apart.
Agregar Comentario
Pull off the keypad. Pull off the keypad.
  • Pull off the keypad.
Agregar Comentario
Gently pull off the infra red window and the vibra motor. Gently pull off the infra red window and the vibra motor. Gently pull off the infra red window and the vibra motor.
  • Gently pull off the infra red window and the vibra motor.
Agregar Comentario
Remove the circuit board and screen from the device. Use your T6 to remove the 4 screws holding the cover on. Use your T6 to remove the 4 screws holding the cover on.
  • Remove the circuit board and screen from the device.
  • Use your T6 to remove the 4 screws holding the cover on.
Agregar Comentario
Remove the board and screen. Remove the board and screen. Remove the board and screen.
  • Remove the board and screen.
Agregar Comentario
Lever out the microphone using a small screwdriver or any similar tool. Lever out the microphone using a small screwdriver or any similar tool.
  • Lever out the microphone using a small screwdriver or any similar tool.
Agregar Comentario
Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board.
  • Carefully remove the plastic clips holding the screen on the board.
Agregar Comentario
Remove the speaker located in the screen housing just above the screen. Gently pry it out with a small screwdriver or similar tool. Gently pry it out with a small screwdriver or similar tool.
  • Remove the speaker located in the screen housing just above the screen.
  • Gently pry it out with a small screwdriver or similar tool.
Agregar Comentario
Remove the plate from the circuit board protecting the more delicate processing parts. Remove the plate from the circuit board protecting the more delicate processing parts. Remove the plate from the circuit board protecting the more delicate processing parts.
  • Remove the plate from the circuit board protecting the more delicate processing parts.
Agregar Comentario
Congratulations, you have successfully disassembled your Sony Ericsson T68i!
  • Congratulations, you have successfully disassembled your Sony Ericsson T68i!
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Tim Dascomb
Miembro Desde 13/04/10
123 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 26-34, Regan Spring 2010 Miembro de Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Miembros
13 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 11
Todo El Tiempo: 5,510
