Introducción
We will be taking off the back cover, or case, of the camera to gain access to the internal components including the speaker, LCD screen, lens, and motherboard.
Partes
No se requieren partes.
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
  • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
  • Remove both batteries.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the single visible screw from both sides of the camera. Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
  • Remove the single visible screw from both sides of the camera.
  • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
  • Do NOT remove all four screws from the bottom.
Agregar Comentario
Gently remove the back cover from the camera. The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  • Gently remove the back cover from the camera.
  • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Thomas
Miembro Desde 14/04/10
109 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 15-50, Garner Spring 2010 Miembro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 5,073
