Introducción
The front housing includes the motor, the chuck, and the gears. There's a good chance that whatever needs to be replaced will be found in here.
Partes
No se requieren partes.
On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
Agregar Comentario
Pull the front housing apart from the rear. The motor and gears might fall out when you are pulling it apart.
  • Pull the front housing apart from the rear.
  • The motor and gears might fall out when you are pulling it apart.
Agregar Comentario
Conclusión
Matt
Miembro Desde 10/10/10
365 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-17, Maness Fall 2010 Miembro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 80
