Saltar al contenido principal
Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing
Qué necesitas
  1. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing, Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 1, imagen 1 de 1
    • Camera lens are delicate and intricate. Be careful with the disassembly and work slowly.
    • Take the lens away from camera
    • DO NOT FORGET: THAT YOU ARE DOING ALL ON YOUR OWN RESPONSIBILITY
  2. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 2, imagen 1 de 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 2, imagen 2 de 2
    • Unscrew the top part and detach it.
    • Unjoin cables. Be careful; they're delicate, and easily torn.
    • Try to avoid touching sensitive electronic components.
    • Unfasten the screws that hold the circuit board in place, and separate it from the rest of the lens assembly.
  3. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 3, imagen 1 de 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 3, imagen 2 de 2
    • Take away zoom rubber and you will find srews
  4. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 4, imagen 1 de 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 4, imagen 2 de 2
    • Keep unscrewing and removing the parts until you reach what you need to fix.
    • Zoom bearing can be taken away by unscrewing its srews.
  5. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: paso 5, imagen 1 de 1
    • Here is one of the parts which was broken, so I go to camera repair shop, and bought that parts. As this was not the only part broken, I had to leave for additional repair.
    • When you finish you can put all back together
Conclusión
6 personas más completaron esta guía.
Rimvydas
Miembro Desde 03/29/12
718 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 58
Todo El Tiempo: 30,157
