Saltar al contenido principal
Disassembling Samsung SPH-A760 Screen
Qué necesitas
  1. Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Battery: paso 1, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Battery: paso 1, imagen 2 de 2
    • Push open the latch and remove the battery.
  2. Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Antenna: paso 2, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Antenna: paso 2, imagen 2 de 2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Disassembling Samsung SPH-A760 Screen, Logic Board: paso 3, imagen 1 de 1
    • Remove the five screws as shown.
  4. Disassembling Samsung SPH-A760 Screen: paso 4, imagen 1 de 1
    • Carefully pry the back plate off.
  5. Disassembling Samsung SPH-A760 Screen: paso 5, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen: paso 5, imagen 2 de 2
    • Carefully detach golden screen connector.
  6. Disassembling Samsung SPH-A760 Screen: paso 6, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen: paso 6, imagen 2 de 2
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Disassembling Samsung SPH-A760 Screen: paso 7, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen: paso 7, imagen 2 de 2
    • Place the logic board on a clean tray.
  8. Disassembling Samsung SPH-A760 Screen, Speakers: paso 8, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen, Speakers: paso 8, imagen 2 de 2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Disassembling Samsung SPH-A760 Screen: paso 9, imagen 1 de 3 Disassembling Samsung SPH-A760 Screen: paso 9, imagen 2 de 3 Disassembling Samsung SPH-A760 Screen: paso 9, imagen 3 de 3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Disassembling Samsung SPH-A760 Screen: paso 10, imagen 1 de 3 Disassembling Samsung SPH-A760 Screen: paso 10, imagen 2 de 3 Disassembling Samsung SPH-A760 Screen: paso 10, imagen 3 de 3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
  11. Disassembling Samsung SPH-A760 Screen, Screen: paso 11, imagen 1 de 2 Disassembling Samsung SPH-A760 Screen, Screen: paso 11, imagen 2 de 2
    • Remove the three screws as shown.
    • Pull off the metal bracket.
  12. Disassembling Samsung SPH-A760 Screen: paso 12, imagen 1 de 3 Disassembling Samsung SPH-A760 Screen: paso 12, imagen 2 de 3 Disassembling Samsung SPH-A760 Screen: paso 12, imagen 3 de 3
    • Use the spudger to pop off the screen.
    • Pop off the Microphone/Speaker as well.
    • Place all of the components on a clean tray and clean environment.
Conclusión
David
Miembro Desde 04/19/10
25 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-43, Garner Spring 2010 Miembro de Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,906
