Introducción
How to remove keyboard
Push open the latch and remove the battery. Push open the latch and remove the battery.
  • Push open the latch and remove the battery.
Agregar Comentario
Twist off the antenna. Pop off the transparent cylinder.
  • Twist off the antenna.
  • Pop off the transparent cylinder.
Agregar Comentario
Remove the five screws as shown.
  • Remove the five screws as shown.
Agregar Comentario
Carefully pry the back plate off.
  • Carefully pry the back plate off.
Agregar Comentario
Carefully detach golden screen connector. Carefully detach golden screen connector.
  • Carefully detach golden screen connector.
Agregar Comentario
Pop out the logic board with spudger. Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  • Pop out the logic board with spudger.
  • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
Agregar Comentario
Place the logic board on a clean tray. Place the logic board on a clean tray.
  • Place the logic board on a clean tray.
Agregar Comentario
Peel off the keyboard.
  • Peel off the keyboard.
Agregar Comentario
Conclusión
doconnor
Miembro Desde 19/04/10
25 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 10-43, Garner Spring 2010 Miembro de Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,059
