Introducción
This is the first few steps for disassembling the DVD player.
Partes
No se requieren partes.
Open the tray by pressing the eject button Remove the DVD tray faceplate by pushing the faceplate up off of the tray. Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  • Open the tray by pressing the eject button
  • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Agregar Comentario
Press the eject button to insert the tray
  • Press the eject button to insert the tray
  • After the tray is closed unplug DVD player
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Unscrew the 3 screws in the back.
  • Unscrew the 3 screws in the back.
Agregar Comentario
Pull the outer case upward and then towards you. Pull the outer case upward and then towards you.
  • Pull the outer case upward and then towards you.
Agregar Comentario
There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate. There are six symmetrically placed tabs holding in the front faceplate.  Unhook these six tabs to loosen the faceplate.
  • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
Agregar Comentario
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously. Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Mitchell Hart
Miembro Desde 21/01/11
819 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-30, Regan Winter 2011 Miembro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 10
Todo El Tiempo: 2,280
