Saltar al contenido principal
Disassembling Rival 16131 Toaster Shell
Qué necesitas
  1. Disassembling Rival 16131 Toaster Shell, Shell: paso 1, imagen 1 de 2 Disassembling Rival 16131 Toaster Shell, Shell: paso 1, imagen 2 de 2
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
  2. Disassembling Rival 16131 Toaster Shell: paso 2, imagen 1 de 2 Disassembling Rival 16131 Toaster Shell: paso 2, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
  3. Disassembling Rival 16131 Toaster Shell: paso 3, imagen 1 de 3 Disassembling Rival 16131 Toaster Shell: paso 3, imagen 2 de 3 Disassembling Rival 16131 Toaster Shell: paso 3, imagen 3 de 3
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
  4. Disassembling Rival 16131 Toaster Shell: paso 4, imagen 1 de 1
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
Conclusión
9 personas más completaron esta guía.
Equipo
Cal Poly, Team 2-8, Propen Fall 2012 Miembro de Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 3,880
