Saltar al contenido principal
Disassembling RCA CC310 Left Cover
Qué necesitas
  1. Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: paso 1, imagen 1 de 2 Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: paso 1, imagen 2 de 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. Disassembling RCA CC310 Left Cover: paso 2, imagen 1 de 2 Disassembling RCA CC310 Left Cover: paso 2, imagen 2 de 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. Disassembling RCA CC310 Left Cover: paso 3, imagen 1 de 2 Disassembling RCA CC310 Left Cover: paso 3, imagen 2 de 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. Disassembling RCA CC310 Left Cover: paso 4, imagen 1 de 2 Disassembling RCA CC310 Left Cover: paso 4, imagen 2 de 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Conclusión
Equipo
Cal Poly, Team 5-20, Amido Winter 2011 Miembro de Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 918
