Peligro
Potencialmente Peligroso
Una lesión puede resultar si este procedimiento no se sigue correctamente. Ten precaución y sigue todas las advertencias.
Peligro
Partes
No se requieren partes.
Disconnect the power supply cord from the outlet.
  • Disconnect the power supply cord from the outlet.
Agregar Comentario
Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
  • Remove the eight screws holding the wood-patterned cover to the microwave frame.
  • The first four screws are located on either side of the microwave front.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
  • Remove the additional four screws securing the wood-paneled case to the microwave frame.
Agregar Comentario
Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
  • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
  • Lift the case upward slowly until the case is free of the microwave.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Samuel
Miembro Desde 26/09/12
100 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-12, Propen Fall 2012 Miembro de Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 15
Todo El Tiempo: 1,421
