Introducción
How to replace the LCD screen if it is broken or cracked.
Partes
No se requieren partes.
Locate the battery cover on the bottom of the camera.
  • Locate the battery cover on the bottom of the camera.
Agregar Comentario
Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
Agregar Comentario
Remove the batteries from the camera.
  • Remove the batteries from the camera.
Agregar Comentario
Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
Agregar Comentario
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
  • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
  • Repeat this step for the back casing.
Agregar Comentario
Locate the black plastic strip under the screen above the white plastic strip.
  • Locate the black plastic strip under the screen above the white plastic strip.
Agregar Comentario
Pull up both sides of the black piece up about a mm.
  • Pull up both sides of the black piece up about a mm.
  • The black plastic piece is not meant to come all the way off, just enough to release the screen.
  • Once the piece is lifted carefully slide the screen out of the slot.
Agregar Comentario
Conclusión
Dani
Miembro Desde 24/06/10
21 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 3-3, Johann Summer 2010 Miembro de Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,515
