Saltar al contenido principal
Disassembling Panasonic GU87 Main-LCD
Qué necesitas
  1. Disassembling Panasonic GU87 Main-LCD, LCD Cover removal: paso 1, imagen 1 de 1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Main-LCD: paso 2, imagen 1 de 1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Main-LCD, LCD: paso 3, imagen 1 de 1
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Main-LCD: paso 4, imagen 1 de 1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 Main-LCD, Main Board: paso 5, imagen 1 de 1
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 Main-LCD: paso 6, imagen 1 de 1
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 Main-LCD: paso 7, imagen 1 de 1
    • Pull/pivot the LCD main board as shown in order to remove.
  8. Disassembling Panasonic GU87 Main-LCD, Disassembling Panasonic GU87 Main-LCD: paso 8, imagen 1 de 1
    • Use tweezers to lift up the main LCD.
Conclusión
Van
Miembro Desde 06/24/10
7 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 2-10, Johann Summer 2010 Miembro de Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,201
