Introducción
Use this guide to separate the face plate from the amplifier.
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Agregar Comentario
Remove the top screw on the back panel. Remove the top screw on the back panel.
  • Remove the top screw on the back panel.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
  • Slide off the case to expose the internal components of the receiver.
Agregar Comentario
Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate.
  • Unscrew the three screws on top of the face plate.
Agregar Comentario
Unscrew the one screw on the bottom of the front panel. Unscrew the one screw on the bottom of the front panel.
  • Unscrew the one screw on the bottom of the front panel.
Agregar Comentario
Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
  • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ryan
Miembro Desde 13/04/10
86 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 27-92, Amido Spring 2010 Miembro de Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Miembros
7 Guías creadas
I would like to remove Front Face plate of my Onkyo TX-SR875 AV Receiver. Please guide me how can I open it?
Ashish Solanki - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 8
Todo El Tiempo: 2,246
