Introducción
Use this guide to remove the side panels to access parts inside.
Qué necesitas
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Remove the top screws using a 1.5 mm screwdriver.
Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
