First remove back cover, battery, chip and memory card .
  • First remove back cover, battery, chip and memory card .
Agregar Comentario
Remove 4 Torx T5 screws. Remove 4 Torx T5 screws.
  • Remove 4 Torx T5 screws.
the Screws can be TX4
Stephan - Contestar
Press these four latches (each side has two) to open front cover. Press these four latches (each side has two) to open front cover.
  • Press these four latches (each side has two) to open front cover.
Agregar Comentario
Carefully remove the front cover with blade tool.
  • Carefully remove the front cover with blade tool.
Agregar Comentario
Carefully remove the bottom cover. This cover has no screws, only latches. Carefully remove the bottom cover. This cover has no screws, only latches.
  • Carefully remove the bottom cover. This cover has no screws, only latches.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Front cover, rubber keyboard and bottom cover removed.
  • Front cover, rubber keyboard and bottom cover removed.
Agregar Comentario
Remove these two Torx T6 screws at top of the smartphone. Remove these two Torx T6 screws at top of the smartphone.
  • Remove these two Torx T6 screws at top of the smartphone.
These screws can also TX4
Stephan - Contestar
Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
  • Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
Agregar Comentario
Base assembly with small connectors and parts.
  • Base assembly with small connectors and parts.
Agregar Comentario
Remove the LCD connector.
  • Remove the LCD connector.
Agregar Comentario
Carefully open the LCD and keyboard assembly, and remove keyboard connector.
  • Carefully open the LCD and keyboard assembly, and remove keyboard connector.
Agregar Comentario
Both sides of the LCD and keyboard assembly removed. Both sides of the LCD and keyboard assembly removed.
  • Both sides of the LCD and keyboard assembly removed.
Agregar Comentario
I think that two small blocks are the gps antenna.
  • I think that two small blocks are the gps antenna.
Agregar Comentario
Both sides of battery - for reference only. Both sides of battery - for reference only.
  • Both sides of battery - for reference only.
Agregar Comentario
Conclusión
26 personas más completaron esta guía.
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
cyfcyf - Contestar
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Samuel Wyatt -
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Dev Abokhadra - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 8
Últimos 30 Días: 78
Todo El Tiempo: 30,108
