Partes
No se requieren partes.
To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it. Now slide the back cover off of the phone.
  • To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
  • Now slide the back cover off of the phone.
Agregar Comentario
Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
  • Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use your finger to lift the battery out.
  • Use your finger to lift the battery out.
  • The E61i uses a Nokia BP-4L standard battery.
Agregar Comentario
Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver. Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
  • Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
Agregar Comentario
After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
  • After the screws have been removed, there is nothing else securing the front cover to the rest of the phone. Simply remove the cover by pulling it up and off.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 9-63, Walters Spring 2011 Miembro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,743
