Introducción
This guide is a step by step process to remove the top cover of the phone. It is the preliminary step, in order to gain access into the upper section of the phone.
Partes
No se requieren partes.
Turn off the phone.
  • Turn off the phone.
  • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
  • Position the phone so that the back side is in view.
Agregar Comentario
Remove the back battery cover. Apply pressure on the cover while simultaneously sliding the cover downward. Apply pressure on the cover while simultaneously sliding the cover downward.
  • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Insert the iPod opening tool between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. The battery lifts out of the phone fast and easily.
  • Insert the iPod opening tool between the base of the phone and the phone battery.
  • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
  • Carefully lift the battery out of the phone.
Agregar Comentario
Close the phone.
  • Close the phone.
  • Face the front cover forward.
Agregar Comentario
Locate the 4.5 mm notch at the top of the phone. Place the iPod opening tool into the opening.
  • Locate the 4.5 mm notch at the top of the phone.
  • Place the iPod opening tool into the opening.
  • Slightly prop up the top section by lifting the tool.
Agregar Comentario
Wedge the iPod opening tool between the top cover and the phone. Gently lift the top cover away from the phone using the iPod opening tool. This unlatches each hook that connects the top cover to the phone.
  • Wedge the iPod opening tool between the top cover and the phone.
  • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
  • Repeat for both the left and the right sides of the phone.
  • Place the top cover aside once the top cover is completely disconnected from the phone.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Andrea
Miembro Desde 15/04/10
70 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 26-30, Regan Spring 2010 Miembro de Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Miembros
17 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 2,066
