Introducción
This guide is a step by step procedure to disassemble the base of the phone. It is the preliminary step in gaining access to the inner components of the Nokia 6086.
Partes
No se requieren partes.
Turn off the phone.
  • Turn off the phone.
  • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
  • Position the phone so that the back side is in view.
Agregar Comentario
Remove the back battery cover. Apply pressure on the cover while simultaneously sliding the cover downward. Apply pressure on the cover while simultaneously sliding the cover downward.
  • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
Agregar Comentario
Insert the iPod opening tool between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. The battery lifts out of the phone fast and easily.
  • Insert the iPod opening tool between the base of the phone and the phone battery.
  • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
  • Carefully lift the battery out of the phone.
Agregar Comentario
Turn the phone so that the back of the phone is facing forward.
  • Turn the phone so that the back of the phone is facing forward.
  • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Place the iPod opening tool under the tabs near the top of the phone. Slide the iPod Opening Tool upwards.
  • Place the iPod opening tool under the tabs near the top of the phone.
  • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
  • Repeat for the left and the right sides.
Agregar Comentario
Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture). Lift the iPod opening tool to pop open the clips.
  • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
  • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
Agregar Comentario
Push upward on the top back cover using two thumbs. This will remove the top back cover from the phone. This will remove the top back cover from the phone.
  • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
Agregar Comentario
Locate the four screws. Remove the screws using a T6 Torx screwdriver.
  • Locate the four screws.
  • Remove the screws using a T6 Torx screwdriver.
Agregar Comentario
Turn the phone over. Gently pull apart the phone.
  • Turn the phone over.
  • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
Agregar Comentario
The phone should now be in two different sections. 1) The logic board and the back cover
  • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Andrea
Miembro Desde 15/04/10
70 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 26-30, Regan Spring 2010 Miembro de Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Miembros
17 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 3,328
