Introducción
This guide will show you how to remove the microphone from the Nokia 3560.
Partes
No se requieren partes.
Press down on the release latch on the bottom of the cover. Once the latch is released, lift the cover from the phone.
  • Press down on the release latch on the bottom of the cover.
  • Once the latch is released, lift the cover from the phone.
Agregar Comentario
Lift the front case off of the phone body.
  • Lift the front case off of the phone body.
Agregar Comentario
Lift the keypad off of the phone. Lift the keypad off of the phone.
  • Lift the keypad off of the phone.
Agregar Comentario
The screen is held to the body by six screws.
  • The screen is held to the body by six screws.
Agregar Comentario
Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
  • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
Agregar Comentario
Insert a flat screwdriver between the black body and plastic layer. Insert a flat screwdriver between the black body and plastic layer.
  • Insert a flat screwdriver between the black body and plastic layer.
Agregar Comentario
Pry the layers apart. The LCD and plastic layer will lift out as one piece.
  • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
Agregar Comentario
With the screws removed, the logic board can then be lifted out of the body by hand.
  • With the screws removed, the logic board can then be lifted out of the body by hand.
Agregar Comentario
Use tweezers to securely grip the microphone, then pull.
  • Use tweezers to securely grip the microphone, then pull.
  • Be careful not to remove the metal prongs.
Agregar Comentario
Conclusión
Sam Ryan
Miembro Desde 18/04/10
1 Reputación
16 Guías creadas
Equipo
Cal Poly, Team 30-39, Garner Spring 2010 Miembro de Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,751
