Introducción
We will now disassemble the guts of the phone, including the SIM card reader, vibrating unit, power toggle button, audio speaker, power assembly/microphone, and the battery connector.
Partes
No se requieren partes.
Hold the phone and push the white button with your thumb. While pressing the button, slide the back plate up (towards the top of the phone) and off the phone. While pressing the button, slide the back plate up (towards the top of the phone) and off the phone.
  • Hold the phone and push the white button with your thumb.
  • While pressing the button, slide the back plate up (towards the top of the phone) and off the phone.
Agregar Comentario
Locate grey buttons beneath battery (shown). Spread buttons simultaneously away from each other and the battery will pop out.
  • Locate grey buttons beneath battery (shown).
  • Spread buttons simultaneously away from each other and the battery will pop out.
  • Remove battery from phone.
Agregar Comentario
Where shown, spread the front faceplate and push forward. Flip over the device, and pry the faceplate away.
  • Where shown, spread the front faceplate and push forward.
  • Flip over the device, and pry the faceplate away.
Agregar Comentario
Remove six T6 screws. Remove six T6 screws.
  • Remove six T6 screws.
Agregar Comentario
Insert spudger between screen assembly and phone body. Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  • Insert spudger between screen assembly and phone body.
  • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove logic board as shown. Remove logic board as shown.
  • Remove logic board as shown.
Agregar Comentario
Use the following legend to locate each component:
    • Use the following legend to locate each component:
      • Microphone/power assembly.
      • Vibrating unit.
      • SIM card reader.
      • Audio speaker.
      • Power toggle button.
      • Battery connector.
Agregar Comentario
Insert spudger between power assembly/micro-phone and phone body. Pry as shown and remove the power assembly/microphone.
  • Insert spudger between power assembly/micro-phone and phone body.
  • Pry as shown and remove the power assembly/microphone.
Agregar Comentario
Once located, the following components are easily removed by pulling them out with your hand.
  • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
Agregar Comentario
Audio speaker. Audio speaker.
  • Audio speaker.
Agregar Comentario
SIM card reader. SIM card reader.
  • SIM card reader.
Agregar Comentario
Vibrating unit. Vibrating unit.
  • Vibrating unit.
Agregar Comentario
Power toggle button. Power toggle button.
Agregar Comentario
Battery connector. Battery connector.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Nico Lee
Miembro Desde 19/04/10
54 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 30-41, Garner Spring 2010 Miembro de Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,735
