Saltar al contenido principal
Disassembling Nokia 3100b Microphone
Qué necesitas
  1. Disassembling Nokia 3100b Microphone, Battery: paso 1, imagen 1 de 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Microphone: paso 2, imagen 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Microphone, SIM Card: paso 3, imagen 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Microphone: paso 4, imagen 1 de 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Microphone, Microphone: paso 5, imagen 1 de 1
    • Press the black tabs to release the front cover from the phone.
  6. Disassembling Nokia 3100b Microphone: paso 6, imagen 1 de 1
    • Remove the front cover from the phone.
    • Set the front cover, as indicated, aside.
  7. Disassembling Nokia 3100b Microphone: paso 7, imagen 1 de 1
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  8. Disassembling Nokia 3100b Microphone: paso 8, imagen 1 de 1
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  9. Disassembling Nokia 3100b Microphone: paso 9, imagen 1 de 1
    • Note the location of the microphone.
  10. Disassembling Nokia 3100b Microphone: paso 10, imagen 1 de 1
    • Use tweezers to remove the microphone from the phone's base.
  11. Disassembling Nokia 3100b Microphone: paso 11, imagen 1 de 1
    • The microphone is now removed.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 29-64, Johann Spring 2010 Miembro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,082
