Introducción
This guide show you how to access the phone's microphone, the component that receives sound when making a call.
Partes
No se requieren partes.
Make sure your phone is turned off.
  • Make sure your phone is turned off.
Agregar Comentario
Press the button on the back of the phone and slide the back panel off.
  • Press the button on the back of the phone and slide the back panel off.
  • Remove the battery by pulling it from the phone.
Agregar Comentario
Note the small metal frame that  hold the SIM card into place.
  • Note the small metal frame that hold the SIM card into place.
  • Gently pull back the tab and lift open the frame.
Agregar Comentario
Retrieve your SIM card.
  • Retrieve your SIM card.
Agregar Comentario
Press the black tabs to release the front cover from the phone.
  • Press the black tabs to release the front cover from the phone.
Agregar Comentario
Remove the front cover from the phone.
  • Remove the front cover from the phone.
  • Set the front cover, as indicated, aside.
Agregar Comentario
Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Agregar Comentario
Remove the screen assembly from the phone base.
  • Remove the screen assembly from the phone base.
  • Set the screen assembly aside.
Agregar Comentario
Note the location of the microphone.
  • Note the location of the microphone.
Agregar Comentario
Use tweezers to remove the microphone from the phone's base.
  • Use tweezers to remove the microphone from the phone's base.
Agregar Comentario
The microphone is now removed.
  • The microphone is now removed.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 29-64, Johann Spring 2010 Miembro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 11
Todo El Tiempo: 1,955
