Saltar al contenido principal
Disassembling Nokia 2366i Side Buttons
Qué necesitas
  1. Disassembling Nokia 2366i Side Buttons, Battery: paso 1, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons, Battery: paso 1, imagen 2 de 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Side Buttons: paso 2, imagen 1 de 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Side Buttons: paso 3, imagen 1 de 3 Disassembling Nokia 2366i Side Buttons: paso 3, imagen 2 de 3 Disassembling Nokia 2366i Side Buttons: paso 3, imagen 3 de 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Side Buttons, Rear Case: paso 4, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons, Rear Case: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Side Buttons: paso 5, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons: paso 5, imagen 2 de 2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Side Buttons: paso 6, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons: paso 6, imagen 2 de 2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Side Buttons: paso 7, imagen 1 de 1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
  8. Disassembling Nokia 2366i Side Buttons, Motherboard: paso 8, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons, Motherboard: paso 8, imagen 2 de 2
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
  9. Disassembling Nokia 2366i Side Buttons: paso 9, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons: paso 9, imagen 2 de 2
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
  10. Disassembling Nokia 2366i Side Buttons, Side Buttons: paso 10, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons, Side Buttons: paso 10, imagen 2 de 2
    • Use the spudger to pull off the top orange chip attached to the white tab.
  11. Disassembling Nokia 2366i Side Buttons: paso 11, imagen 1 de 2 Disassembling Nokia 2366i Side Buttons: paso 11, imagen 2 de 2
    • Lightly pull up on the white tab to remove the orange tab from the logic board.
    • Don't worry about the glue on the bottom orange tab. It's only there to keep the side button in place.
Conclusión
Jonathan Newman
Miembro Desde 01/21/11
486 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-14, Amido Winter 2011 Miembro de Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 780
