Partes
No se requieren partes.
Remove the screws from the bottom, right, and left side of camera. Remove the screws from the bottom, right, and left side of camera. Remove the screws from the bottom, right, and left side of camera.
  • Remove the screws from the bottom, right, and left side of camera.
Agregar Comentario
Remove the back of the camera, may require force.
  • Remove the back of the camera, may require force.
Agregar Comentario
Unscrew the right metal bracket of the viewing lens
  • Unscrew the right metal bracket of the viewing lens
Agregar Comentario
Unscrew the top right corner screw
  • Unscrew the top right corner screw
Agregar Comentario
Unscrew the bottom right corner screw.
  • Unscrew the bottom right corner screw.
Agregar Comentario
Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force. Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the front of the camera off of the mother board. Pull the front of the camera off of the mother board.
  • Pull the front of the camera off of the mother board.
Agregar Comentario
Unscrew the grey plastic around the screen
  • Unscrew the grey plastic around the screen
Agregar Comentario
Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
  • Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
Agregar Comentario
Maneuver to detach the flash bulb.
  • Maneuver to detach the flash bulb.
Agregar Comentario
Unscrew the metal bracket under the lens
  • Unscrew the metal bracket under the lens
Agregar Comentario
Slide the plastic bracket through the metal bracket.
  • Slide the plastic bracket through the metal bracket.
Agregar Comentario
  • Remove the orange cable from the motherboard.
Agregar Comentario
Pull the black tape off.
  • Pull the black tape off.
Agregar Comentario
Unscrew the two screws underneath.
  • Unscrew the two screws underneath.
Agregar Comentario
  • Remove lens
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Crista Riedy
Miembro Desde 12/02/13
406 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-2, Buehl Spring 2013 Miembro de Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 499
