Introducción
Today we are going to take you to a step by step guide on how to install a new keypad.
Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
  • Slide the notch downward while pulling the back cover off to remove it.
Agregar Comentario
Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
  • Use your fingers to push the battery upward from the bottom.
  • Lift upwards to remove the battery.
Agregar Comentario
Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
  • Unscrew the antenna in a counter-clockwise fashion.
  • Remove the aluminum cover.
Agregar Comentario
Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
  • Unscrew the 3 screws shown.
  • Lift up the right part of the Nextel logo and unscrew the screw underneath.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
  • DO NOT force the cover off as it could damage the ribbon cable!
  • Gently lift the back cover off.
Agregar Comentario
Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
  • Carefully pry off the connection between the headphone jack and logic board.
Agregar Comentario
Lift the first logic board off of the rest of the device. Lift the first logic board off of the rest of the device.
  • Lift the first logic board off of the rest of the device.
Agregar Comentario
Gently lift the second logic board from the rest of the device.
  • Gently lift the second logic board from the rest of the device.
  • DO NOT force the board straight off as it could damage the ribbon cable!
Agregar Comentario
Using tweezers, carefully pull off the connector shown. Using tweezers, carefully pull off the connector shown.
  • Using tweezers, carefully pull off the connector shown.
Agregar Comentario
Remove the keypad buttons off the front cover of the phone. Remove the keypad buttons off the front cover of the phone. Remove the keypad buttons off the front cover of the phone.
  • Remove the keypad buttons off the front cover of the phone.
Agregar Comentario
Conclusión
Jorge
Miembro Desde 14/04/10
4 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-61, Johann Spring 2010 Miembro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,315
