Introducción
This guide explains how to remove the battery.
Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
  • Slide the notch downward while pulling the back cover off to remove it.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
  • Use your fingers to push the battery upward from the bottom.
  • Lift upwards to remove the battery.
Agregar Comentario
Conclusión
Jorge
Miembro Desde 14/04/10
4 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-61, Johann Spring 2010 Miembro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,230
