Introducción
Disassembling top half to get to connector ribbon, inside screen, and speaker.
Pull at top of faceplate, and it will pop off.
  • Pull at top of faceplate, and it will pop off.
Agregar Comentario
Unscrew four screws on front cover.
  • Unscrew four screws on front cover.
Agregar Comentario
Slide out metallic silver cover.
  • Slide out metallic silver cover.
  • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
Agregar Comentario
Use a tool to wedge in between the silver and black parts on the cover.
  • Use a tool to wedge in between the silver and black parts on the cover.
  • Silver part should now snap off.
Agregar Comentario
Black rubber part may now be easily removed.
  • Black rubber part may now be easily removed.
Agregar Comentario
Use a soldering iron to disconnect the connector ribbon from the phone.
  • Use a soldering iron to disconnect the connector ribbon from the phone.
Agregar Comentario
Conclusión
Tyler Knisley
Miembro Desde 07/05/10
1 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 6-16, Maness Spring 2010 Miembro de Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,511
