Saltar al contenido principal
Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
Qué necesitas
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: paso 1, imagen 1 de 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: paso 1, imagen 2 de 2
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: paso 2, imagen 1 de 1
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: paso 3, imagen 1 de 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: paso 3, imagen 2 de 2
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: paso 4, imagen 1 de 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: paso 4, imagen 2 de 2
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
Conclusión
4 personas más completaron esta guía.
RoggeSound
Miembro Desde 06/05/10
2,345 Reputación
1 Guía escrita
2 comentarios
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - Contestar
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 6,752
