Introducción
The Macintosh IIsi came with a red-ribbon 1.44MB "SuperDrive" (and yes, just like DVD-Burning "SuperDrives" this was the best available option)
Partes
No se requieren partes.
Start by turning the computer around, and remove this #0 Phillips Screw. There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  • Start by turning the computer around, and remove this #0 Phillips Screw.
  • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
Agregar Comentario
Now lift these two clips, and slowly pivot the case up. You can now seperate the top of the computer from the rest of the machine. You can now seperate the top of the computer from the rest of the machine.
  • Now lift these two clips, and slowly pivot the case up.
  • You can now seperate the top of the computer from the rest of the machine.
Agregar Comentario
The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it. Push these two tabs out, and lift the drive up. Push these two tabs out, and lift the drive up.
  • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
  • Push these two tabs out, and lift the drive up.
Agregar Comentario
Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable. 1.44MB floppy drives need a ribbon cable with a red stripe on one side.  400KB floppy drives use a ribbon cable with a yellow stripe on one side.  800KB floppy drives can use a red, or yellow striped cable. This drive was manufactured by Sony in 1990.
  • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
  • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
  • This drive was manufactured by Sony in 1990.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Chris Green
Miembro Desde 11/10/09
31,845 Reputación
46 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
275 Miembros
716 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 2,421
