Saltar al contenido principal
Disassembling LG VX8550 Front Case
Qué necesitas
  1. Disassembling LG VX8550 Front Case, Battery: paso 1, imagen 1 de 1
    • Slide the battery release up.
  2. Disassembling LG VX8550 Front Case: paso 2, imagen 1 de 1
    • Remove the battery by lifting away from the case.
  3. Disassembling LG VX8550 Front Case, Case: paso 3, imagen 1 de 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Disassembling LG VX8550 Front Case: paso 4, imagen 1 de 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Disassembling LG VX8550 Front Case: paso 5, imagen 1 de 1
    • Use the iPod opening tool to pry off the back casing.
  6. Disassembling LG VX8550 Front Case: paso 6, imagen 1 de 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. Disassembling LG VX8550 Front Case: paso 7, imagen 1 de 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. Disassembling LG VX8550 Front Case, Motherboard: paso 8, imagen 1 de 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. Disassembling LG VX8550 Front Case: paso 9, imagen 1 de 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. Disassembling LG VX8550 Front Case: paso 10, imagen 1 de 1
    • Remove the motherboard from the front casing by lifting straight up.
  11. Disassembling LG VX8550 Front Case, Keypad Housing: paso 11, imagen 1 de 1
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. Disassembling LG VX8550 Front Case: paso 12, imagen 1 de 1
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. Disassembling LG VX8550 Front Case: paso 13, imagen 1 de 1
    • Lift the keypad housing away from the slider.
  14. Disassembling LG VX8550 Front Case, Front Case: paso 14, imagen 1 de 1
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. Disassembling LG VX8550 Front Case: paso 15, imagen 1 de 1
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. Disassembling LG VX8550 Front Case: paso 16, imagen 1 de 1
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. Disassembling LG VX8550 Front Case: paso 17, imagen 1 de 1
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. Disassembling LG VX8550 Front Case: paso 18, imagen 1 de 1
    • Slide ribbon cable through the slider mechanism.
  19. Disassembling LG VX8550 Front Case: paso 19, imagen 1 de 1
    • Separate the two halves.
Conclusión
Nathan Jones
Miembro Desde 04/10/10
89 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 34-55, Forte Spring 2010 Miembro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,044
