Introducción
These instructions will demonstrate how to remove the keyboard from the KDDI Kyocera A5521K.
Partes
No se requieren partes.
Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
  • Turn the phone over to expose the battery cover.
  • Apply pressure to the back of the battery cover to slide it down.
  • The battery cover is now separate from the phone.
Agregar Comentario
Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
  • Remove the battery by pushing it up and out from the bottom.
  • The battery, cover, and phone should now be separated.
Agregar Comentario
Remove the four screws with the Y0 screwdriver. Remove the four screws with the Y0 screwdriver.
  • Remove the four screws with the Y0 screwdriver.
Agregar Comentario
Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws. Remove the two screws with a Y0 screwdriver.
  • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
  • Remove the two screws with a Y0 screwdriver.
Agregar Comentario
Rotate the phone 180 degrees. Carefully separate the back plate from the remainder of the phone. The back plate should now be detached from the rest of the phone.
  • Rotate the phone 180 degrees.
  • Carefully separate the back plate from the remainder of the phone.
  • The back plate should now be detached from the rest of the phone.
Agregar Comentario
Lift up the bottom of the logic board. Carefully remove the logic board from the lower half of the phone. The logic board is connected to the remainder of the phone by two cables at the upper right corner indicated by the red circle.  Do not damage the cables.
  • Lift up the bottom of the logic board.
  • Carefully remove the logic board from the lower half of the phone.
  • The logic board is connected to the remainder of the phone by two cables at the upper right corner indicated by the red circle. Do not damage the cables.
Agregar Comentario
Gently lift the keyboard up with a spudger. The keyboard is now separate from the remainder of the phone and can be easily removed.
  • Gently lift the keyboard up with a spudger.
  • The keyboard is now separate from the remainder of the phone and can be easily removed.
Agregar Comentario
Conclusión
Dominic Grisafe
Miembro Desde 15/04/10
133 Reputación
20 Guías creadas
Equipo
Cal Poly, Team 28-25, Regan Spring 2010 Miembro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,191
