Introducción
These instructions will demonstrate how to remove the faceplate from the KDDI Kyocera A5521K.
Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
  • Turn the phone over to expose the battery cover.
  • Apply pressure to the back of the battery cover to slide it down.
  • The battery cover is now separate from the phone.
Agregar Comentario
Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
  • Remove the battery by pushing it up and out from the bottom.
  • The battery, cover, and phone should now be separated.
Agregar Comentario
Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
  • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the screws using a Y0 screwdriver.
  • Remove the screws using a Y0 screwdriver.
Agregar Comentario
Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
  • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
Agregar Comentario
Use the Y0 screwdriver to remove the screws.
  • Use the Y0 screwdriver to remove the screws.
Agregar Comentario
Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
  • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
Agregar Comentario
Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
  • Separate the faceplate from the phone.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Dominic Grisafe
Miembro Desde 15/04/10
133 Reputación
20 Guías creadas
Equipo
Cal Poly, Team 28-25, Regan Spring 2010 Miembro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,565
