Saltar al contenido principal
Disassembling KDDI Kyocera A5521K Back Plate
Qué necesitas
  1. Disassembling KDDI Kyocera A5521K Back Plate, Disassembling KDDI Kyocera A5521K Battery: paso 1, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Back Plate, Disassembling KDDI Kyocera A5521K Battery: paso 1, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Back Plate, Disassembling KDDI Kyocera A5521K Battery: paso 1, imagen 3 de 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Back Plate: paso 2, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Back Plate: paso 2, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Back Plate: paso 2, imagen 3 de 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Back Plate, Back Plate: paso 3, imagen 1 de 2 Disassembling KDDI Kyocera A5521K Back Plate, Back Plate: paso 3, imagen 2 de 2
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Back Plate: paso 4, imagen 1 de 2 Disassembling KDDI Kyocera A5521K Back Plate: paso 4, imagen 2 de 2
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Back Plate: paso 5, imagen 1 de 3 Disassembling KDDI Kyocera A5521K Back Plate: paso 5, imagen 2 de 3 Disassembling KDDI Kyocera A5521K Back Plate: paso 5, imagen 3 de 3
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
Conclusión
2 personas más completaron esta guía.
Dominic Grisafe
Miembro Desde 04/15/10
157 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 28-25, Regan Spring 2010 Miembro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 2,822
