Saltar al contenido principal
Disassembling IBM ThinkPad A30 Upper Case
Qué necesitas
  1. Disassembling IBM ThinkPad A30 Upper Case, Battery: paso 1, imagen 1 de 2 Disassembling IBM ThinkPad A30 Upper Case, Battery: paso 1, imagen 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: paso 2, imagen 1 de 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: paso 2, imagen 2 de 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: paso 2, imagen 3 de 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: paso 3, imagen 1 de 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Disassembling IBM ThinkPad A30 Upper Case: paso 4, imagen 1 de 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Disassembling IBM ThinkPad A30 Upper Case: paso 5, imagen 1 de 2 Disassembling IBM ThinkPad A30 Upper Case: paso 5, imagen 2 de 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Disassembling IBM ThinkPad A30 Upper Case: paso 6, imagen 1 de 3 Disassembling IBM ThinkPad A30 Upper Case: paso 6, imagen 2 de 3 Disassembling IBM ThinkPad A30 Upper Case: paso 6, imagen 3 de 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Disassembling IBM ThinkPad A30 Upper Case: paso 7, imagen 1 de 3 Disassembling IBM ThinkPad A30 Upper Case: paso 7, imagen 2 de 3 Disassembling IBM ThinkPad A30 Upper Case: paso 7, imagen 3 de 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Disassembling IBM ThinkPad A30 Upper Case: paso 8, imagen 1 de 2 Disassembling IBM ThinkPad A30 Upper Case: paso 8, imagen 2 de 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Disassembling IBM ThinkPad A30 Upper Case: paso 9, imagen 1 de 3 Disassembling IBM ThinkPad A30 Upper Case: paso 9, imagen 2 de 3 Disassembling IBM ThinkPad A30 Upper Case: paso 9, imagen 3 de 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
Conclusión
Una persona más ha completado esta guía.
Alan
Miembro Desde 10/07/10
380 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-44, Amido Fall 2010 Miembro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 23
Todo El Tiempo: 2,146
