Introducción
To take the floppy disk drive out, remove the battery first.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
  • Flip the ThinkPad over so that it is upside down.
  • Slide the highlighted tab to the left.
  • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Hold the Thinkpad as the picture shows. There is a switch located just above and to the right of the drive.
  • Hold the Thinkpad as the picture shows.
  • There is a switch located just above and to the right of the drive.
  • Slide the switch to the right. A small, black tab will pop out.
Agregar Comentario
Pull the small black tab away from the computer to access the drive. Gently pull the drive out from the laptop.
  • Pull the small black tab away from the computer to access the drive.
  • Gently pull the drive out from the laptop.
  • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
Agregar Comentario
Conclusión
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
Miembro Desde 06/10/10
159 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 4-44, Amido Fall 2010 Miembro de Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 2,147
