Introducción
This guide will instruct camera owners how to take off the outer casing and how to access the inside components to repair and/or replace broken parts.
Partes
No se requieren partes.
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Agregar Comentario
Locate the battery door.
  • Locate the battery door.
Agregar Comentario
Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
Agregar Comentario
Remove the battery from the camera by pulling the battery door outwards.
  • Remove the battery from the camera by pulling the battery door outwards.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
Agregar Comentario
Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver. Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
Agregar Comentario
Locate the film door latch located on the side of the camera.
  • Locate the film door latch located on the side of the camera.
  • Insert the spudger under the latch.
  • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
  • Pry the latch upward, applying force perpendicular to the camera.
Agregar Comentario
Insert the flat edge of the spudger between the gold front casing and the black back casing.
  • Insert the flat edge of the spudger between the gold front casing and the black back casing.
  • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
Agregar Comentario
Squeeze the camera by placing a thumb on the tab marked CE.
  • Squeeze the camera by placing a thumb on the tab marked CE.
  • Pull the back half of the camera firmly away from the camera body.
Agregar Comentario
Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
Agregar Comentario
Pull the front cover off of the camera by lifting the tripod tab over the tripod hole. Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Agregar Comentario
Conclusión
Eric Nicolai
Miembro Desde 10/01/11
679 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-5, Forte Winter 2011 Miembro de Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,171
