Introducción
This guide will show you how to open the outer shell of your Flip Video.
Partes
No se requieren partes.
Turn off the device and take the batteries out. Remove metal sticker under the LCD screen with a spudger.
  • Turn off the device and take the batteries out.
  • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
Agregar Comentario
Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
Agregar Comentario
Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
Agregar Comentario
Open battery door. This can be done by gently depressing and sliding the battery down downward.
  • Open battery door. This can be done by gently depressing and sliding the battery down downward.
Agregar Comentario
Use the spudger to separate outer shells.
  • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
Agregar Comentario
Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Slowly lift the left side of the circuit board.
  • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
Agregar Comentario
Disconnect the USB port cable from the back side of the circuit board.
  • Disconnect the USB port cable from the back side of the circuit board.
Agregar Comentario
Slide out the battery contacts.
  • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
Agregar Comentario
Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
  • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
Agregar Comentario
Lift wire out of the outer shell slot.
  • Lift wire out of the outer shell slot.
    • The wire mount should stay attached to the wire.
Agregar Comentario
Use tweezers to remove the spring that holds the port door shut.
  • Use tweezers to remove the spring that holds the port door shut.
    • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
Agregar Comentario
Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
  • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
Agregar Comentario
Remove the USB port cover.
  • Remove the USB port cover.
Agregar Comentario
Remove the USB slider.
  • Remove the USB slider.
Agregar Comentario
Lift out the USB port slowly.
  • Lift out the USB port slowly.
    • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Elizabeth
Miembro Desde 15/04/10
100 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 26-21, Regan Spring 2010 Miembro de Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 3,891
