Partes
No se requieren partes.
To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown).  The back panel is the same as the battery. With your index finger, push in the button on the bottom of the battery to release it. Pull the battery away from the phone.
  • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
  • With your index finger, push in the button on the bottom of the battery to release it.
  • Pull the battery away from the phone.
Agregar Comentario
After removing the battery, the front phone casing becomes accessible. Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles. Remove these two screws using the Torx T6 Screwdriver.
  • After removing the battery, the front phone casing becomes accessible.
  • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
  • Remove these two screws using the Torx T6 Screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the top two U-shaped screws on the back of the phone, as shown by the red circles. Remove these two screws with a SP 2.6 screw driver. Note:  Remove gray plastic grommets with screws.
  • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
  • Remove these two screws with a SP 2.6 screw driver.
  • Note: Remove gray plastic grommets with screws.
Agregar Comentario
Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image. Note:  Be careful not to damage the circuit board and components as you as open the casing.
  • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
  • Note: Be careful not to damage the circuit board and components as you as open the casing.
Agregar Comentario
After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown. After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
  • After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
Agregar Comentario
To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen. Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown. Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
  • To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen.
  • Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
Agregar Comentario
Conclusión
Niccolas Tones
Miembro Desde 09/03/12
55 Reputación
18 Guías creadas
Equipo
Clemson, Team 1-1, Benson Spring 2012 Miembro de Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Miembros
21 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 1,048
