Saltar al contenido principal
Disassembling Compaq Mini 110 Fan
Qué necesitas
  1. Disassembling Compaq Mini 110 Fan, Battery: paso 1, imagen 1 de 2 Disassembling Compaq Mini 110 Fan, Battery: paso 1, imagen 2 de 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Disassembling Compaq Mini 110 Fan: paso 2, imagen 1 de 3 Disassembling Compaq Mini 110 Fan: paso 2, imagen 2 de 3 Disassembling Compaq Mini 110 Fan: paso 2, imagen 3 de 3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Disassembling Compaq Mini 110 Fan, RAM: paso 3, imagen 1 de 2 Disassembling Compaq Mini 110 Fan, RAM: paso 3, imagen 2 de 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Disassembling Compaq Mini 110 Fan: paso 4, imagen 1 de 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Disassembling Compaq Mini 110 Fan, Keyboard: paso 5, imagen 1 de 2 Disassembling Compaq Mini 110 Fan, Keyboard: paso 5, imagen 2 de 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Disassembling Compaq Mini 110 Fan: paso 6, imagen 1 de 2 Disassembling Compaq Mini 110 Fan: paso 6, imagen 2 de 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Disassembling Compaq Mini 110 Fan: paso 7, imagen 1 de 2 Disassembling Compaq Mini 110 Fan: paso 7, imagen 2 de 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Disassembling Compaq Mini 110 Fan: paso 8, imagen 1 de 2 Disassembling Compaq Mini 110 Fan: paso 8, imagen 2 de 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Disassembling Compaq Mini 110 Fan, Top Cover: paso 9, imagen 1 de 1
    • Remove the eight screws that are from the plastic top cover.
  10. Disassembling Compaq Mini 110 Fan: paso 10, imagen 1 de 3 Disassembling Compaq Mini 110 Fan: paso 10, imagen 2 de 3 Disassembling Compaq Mini 110 Fan: paso 10, imagen 3 de 3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
  11. Disassembling Compaq Mini 110 Fan: paso 11, imagen 1 de 2 Disassembling Compaq Mini 110 Fan: paso 11, imagen 2 de 2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
  12. Disassembling Compaq Mini 110 Fan, Hard Drive: paso 12, imagen 1 de 1
    • Remove the three screws holding the panel in place.
  13. Disassembling Compaq Mini 110 Fan: paso 13, imagen 1 de 2 Disassembling Compaq Mini 110 Fan: paso 13, imagen 2 de 2
    • Pull up on the tab to remove the hard drive.
  14. Disassembling Compaq Mini 110 Fan, Fan: paso 14, imagen 1 de 2 Disassembling Compaq Mini 110 Fan, Fan: paso 14, imagen 2 de 2
    • Remove the two screws holding the fan in place.
    • There is still a cable attached to the fan so be sure to pull that out as well.
Conclusión
Una persona más ha completado esta guía.
alea
Miembro Desde 10/06/10
1,405 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 22-2, Maness Fall 2010 Miembro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 6,472
