Introducción
Before accessing the screen itself or the built in webcam, you must remove the display assembly from the base.
Partes
No se requieren partes.
Find the battery and the battery tabs located on the bottom of the Compaq Mini. Find the battery and the battery tabs located on the bottom of the Compaq Mini.
  • Find the battery and the battery tabs located on the bottom of the Compaq Mini.
Agregar Comentario
Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out.
  • Push the tabs inward and slide the battery out.
Agregar Comentario
Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment. Note that the screws are attached to the panel.
  • Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment.
    • Note that the screws are attached to the panel.
Agregar Comentario
Push out side tabs.
  • Push out side tabs.
Agregar Comentario
Remove the rubber pads located on the corners of your Compaq Mini. There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  • Remove the rubber pads located on the corners of your Compaq Mini.
  • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
Agregar Comentario
Unscrew all the corner screws. There are four total, one under each rubber pad. Unscrew all the corner screws. There are four total, one under each rubber pad.
  • Unscrew all the corner screws. There are four total, one under each rubber pad.
Agregar Comentario
Unscrew the screw for the bottom case located in the RAM compartment. Unscrew the screw for the bottom case located in the RAM compartment.
  • Unscrew the screw for the bottom case located in the RAM compartment.
Falta um passo, pois nos modelos COMPAQ MINI 110, existe um parafuso que segura o teclado, que se encontra bem escondido dentro da cavidade que encaixa a bateria.
Amilcar Correia - Contestar
Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
  • Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
3 screws in red circles are actually on metal tabs in the battery compartment, 1 deeper than the other 2. There is a keyboard symbol for each of the 3 screws.
Step 8B: Lift out keyboard by pushing upwards on the 2 accessible metal tabs. This is the most difficult step. Lack of Quality Control during assembly may prevent the kevboard from lifting out without breaking!!
John - Contestar
This step may be performed after battery removal. Use care when removing ribbon cable: the white clips holding the black plastic "keeper" are fragile. Reassembly possible without white clips; however, jostling may cause the ribbon to come free.
Jason L - Contestar
Remove the three screws.
  • Remove the three screws.
Agregar Comentario
Pull up on the tab. Pull up on the tab.
  • Pull up on the tab.
Agregar Comentario
Remove the eight screws from the plastic top cover.
  • Remove the eight screws from the plastic top cover.
Agregar Comentario
Pry up the top plastic cover using a spudger. Under the screen there are two tabs that need to be pushed in. Under the screen there are two tabs that need to be pushed in.
  • Pry up the top plastic cover using a spudger.
    • Under the screen there are two tabs that need to be pushed in.
Agregar Comentario
Careful lifting up the cover because the track pad is still attached. Remove the cable by pulling it up.
  • Careful lifting up the cover because the track pad is still attached.
  • Remove the cable by pulling it up.
Agregar Comentario
Take out the four screws that keep the bottom of the hinges attached to the base. Take out the four screws that keep the bottom of the hinges attached to the base. Take out the four screws that keep the bottom of the hinges attached to the base.
  • Take out the four screws that keep the bottom of the hinges attached to the base.
Agregar Comentario
Pry off the top plastic cover of the display assembly. Note: There is adhesive tape holding the cover on. Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
  • Pry off the top plastic cover of the display assembly.
  • Note: There is adhesive tape holding the cover on.
  • Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
alea
Miembro Desde 06/10/10
1,242 Reputación
19 Guías creadas
Equipo
Cal Poly, Team 22-2, Maness Fall 2010 Miembro de Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 7,099
