Introducción
This may need to be removed if the button or scroll wheel is not working.
Partes
No se requieren partes.
Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen. Remove the 2 screws(4.08mm) on the other side.  One is located under the rubber USB flap. Remove the last screw(2.59mm) located on the bottom of the camera.
  • Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen.
  • Remove the 2 screws(4.08mm) on the other side. One is located under the rubber USB flap.
  • Remove the last screw(2.59mm) located on the bottom of the camera.
  • Slowly pull the back cover of the camera.
Agregar Comentario
Remove 2 screws from back of camera using screwdriver. Remove 2 screws holding metal side guard using screwdriver. Remove the connecting ribbon by pulling it straight out.
  • Remove 2 screws from back of camera using screwdriver.
  • Remove 2 screws holding metal side guard using screwdriver.
  • Remove the connecting ribbon by pulling it straight out.
Agregar Comentario
Conclusión
Ben Tupas
Miembro Desde 13/01/11
317 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 1,232
