Introducción
The logic board is the brains behind the camera and should be handled delicately.
Partes
No se requieren partes.
Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen. Remove the 2 screws(4.08mm) on the other side.  One is located under the rubber USB flap. Remove the last screw(2.59mm) located on the bottom of the camera.
  • Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen.
  • Remove the 2 screws(4.08mm) on the other side. One is located under the rubber USB flap.
  • Remove the last screw(2.59mm) located on the bottom of the camera.
  • Slowly pull the back cover of the camera.
Agregar Comentario
Remove the screw(2.59mm) from the bottom of the camera. Remove the screw(4.08mm) from the menu button side of the camera. The 2 screws on the other side of the camera were already removed when taking off the back cover.
  • Remove the screw(2.59mm) from the bottom of the camera.
  • Remove the screw(4.08mm) from the menu button side of the camera.
  • The 2 screws on the other side of the camera were already removed when taking off the back cover.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Unplug the green (if color-blind please ask someone for assistance) and white plugs connecting the top panel to  top of the logic board. Dislodge the tab above the lens.
  • Unplug the green (if color-blind please ask someone for assistance) and white plugs connecting the top panel to top of the logic board.
  • Dislodge the tab above the lens.
  • Dislodge the back tab.
Agregar Comentario
Remove 2 screws(1.75mm) using a screwdriver.
  • Remove 2 screws(1.75mm) using a screwdriver.
  • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
Agregar Comentario
Remove the newly exposed screw(1.75mm) with screwdriver. Unhinge the black tab to slide out the ribbon.
  • Remove the newly exposed screw(1.75mm) with screwdriver.
  • Unhinge the black tab to slide out the ribbon.
  • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Agregar Comentario
Conclusión
Juan Miguel
Miembro Desde 13/01/11
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 1,752
