Introducción
Removing the front cover allows access to the flash assembly.
Partes
No se requieren partes.
Remove one 2.25mm screw on the bottom.
  • Remove one 2.25mm screw on the bottom.
Agregar Comentario
Remove two 2.25mm screws on the right side looking from the front.
  • Remove two 2.25mm screws on the right side looking from the front.
Agregar Comentario
Remove one 4.7mm screw on the side with the AV output.
  • Remove one 4.7mm screw on the side with the AV output.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull off the back cover.
  • Pull off the back cover.
  • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
Agregar Comentario
Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
Agregar Comentario
Remove one 2.25mm screw on the bottom of the camera.
  • Remove one 2.25mm screw on the bottom of the camera.
Agregar Comentario
Pull off the front cover.
  • Pull off the front cover.
Agregar Comentario
Conclusión
Jeremy Rabaino
Miembro Desde 10/10/10
135 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-9, Maness Fall 2010 Miembro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,269
