Saltar al contenido principal
Disassembling Canon PowerShot SD1100 IS Camera Lens
Qué necesitas
  1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: paso 1, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: paso 1, imagen 2 de 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 2, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 2, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 2, imagen 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 3, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 3, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 3, imagen 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 4, imagen 1 de 1
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: paso 5, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: paso 5, imagen 2 de 2
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 6, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 6, imagen 2 de 2
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 7, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 7, imagen 2 de 2
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 8, imagen 1 de 1
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 9, imagen 1 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 9, imagen 2 de 3 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 9, imagen 3 de 3
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 10, imagen 1 de 1
    • The LCD screen should now be removed.
  11. Disassembling Canon PowerShot SD1100 IS Camera Lens, Flash Assembly: paso 11, imagen 1 de 1
    • Remove the screw located on the side of the camera (0.072 in).
  12. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 12, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 12, imagen 2 de 2
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  13. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 13, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 13, imagen 2 de 2
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  14. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 14, imagen 1 de 1
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  15. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 15, imagen 1 de 1
    • The capacitor should now be removed.
  16. Disassembling Canon PowerShot SD1100 IS Camera Lens, Camera Lens: paso 16, imagen 1 de 1
    • Remove 4 screws from silver plate (0.106 in).
  17. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 17, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 17, imagen 2 de 2
    • Use spudger to lift the second lens ribbon.
    • Remember the first ribbon was removed while taking out the flash assembly.
  18. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 18, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 18, imagen 2 de 2
    • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
  19. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 19, imagen 1 de 2 Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 19, imagen 2 de 2
    • Remove the lens.
  20. Disassembling Canon PowerShot SD1100 IS Camera Lens: paso 20, imagen 1 de 1
    • The camera lens should now be removed.
Conclusión
14 personas más completaron esta guía.
Tyler Grossheim
Miembro Desde 01/25/11
1,470 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-32, Regan Winter 2011 Miembro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Miembros
8 Guías creadas
Un comentario
How do you CLEAN the lens?
Christian - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 83
Todo El Tiempo: 20,483
