Saltar al contenido principal
Disassembling Canon Pixma MP480 Rear and Side Panel
Qué necesitas
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: paso 1, imagen 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: paso 1, imagen 2 de 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 2, imagen 1 de 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 3, imagen 1 de 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 4, imagen 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: paso 4, imagen 2 de 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 5, imagen 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: paso 5, imagen 2 de 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 6, imagen 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: paso 6, imagen 2 de 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 7, imagen 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: paso 7, imagen 2 de 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: paso 8, imagen 1 de 2 Disassembling Canon Pixma MP480 Rear and Side Panel: paso 8, imagen 2 de 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Conclusión
6 personas más completaron esta guía.
Kevin Cole
Miembro Desde 01/17/13
116 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 19-41, Regan Winter 2013 Miembro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Miembros
6 Guías creadas
2 comentarios
Where is the rest of disassembly?
bill roberts - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 23
Todo El Tiempo: 21,143
