Introducción
This guide explains how to disassemble the Breville BKC600XL coffee brewer head.
Partes
No se requieren partes.
Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver. Reminder for reassembly; This bottom piece is first to be screwed back on. Reminder for reassembly; This bottom piece is first to be screwed back on.
  • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
  • Reminder for reassembly; This bottom piece is first to be screwed back on.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
Agregar Comentario
Remove the grey plastic casing. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  • Remove the grey plastic casing.
  • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
Agregar Comentario
Conclusión
Antonio
Miembro Desde 26/09/12
73 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-3, Propen Fall 2012 Miembro de Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Miembros
6 Guías creadas
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 21
Todo El Tiempo: 2,586
