Saltar al contenido principal
Dell XPS 1340 CPU Fan Replacement
Qué necesitas
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: paso 1, imagen 1 de 1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: paso 2, imagen 1 de 1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: paso 3, imagen 1 de 1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: paso 4, imagen 1 de 2 Dell XPS 1340 CPU Fan Replacement: paso 4, imagen 2 de 2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: paso 5, imagen 1 de 2 Dell XPS 1340 CPU Fan Replacement: paso 5, imagen 2 de 2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: paso 6, imagen 1 de 1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
Conclusión
4 personas más completaron esta guía.
Paras Tolani
Miembro Desde 03/01/13
188 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,806
